ONTAP Hardware
HA pair FC single path per controller question
datamethz
Hello,
We have recently adquired a FAS2240 dual controller running 8.2P2, options cf.takeover as follow on both nodes:
cf.takeover.bypass_optimization off
cf.takeover.change_fsid      on
cf.takeover.detection.seconds 15
cf.takeover.on_disk_shelf_miscompare off
cf.takeover.on_failure       on
cf.takeover.on_network_interface_failure off
cf.takeover.on_network_interface_failure.policy all_nics   (same value in local+partner recommended)
cf.takeover.on_panic         on
cf.takeover.on_reboot        off
cf.takeover.on_short_uptime  on
cf.takeover.use_mcrc_file    off        (value might be overwritten in takeover)
                  Local
Adapter Type      State                  Status
  1a   initiator  CONFIGURED.            offline
  1b   target     CONFIGURED             online
                  Local
We presented a 50GB LUN to a Linux box, when we do disconnect the FC cable from one of the controllers, the one that owns a LUN, it does not automatically failover to the other controller but instead the Linux box stops seeing the LUN.
is it possible to have the HA configuration takeover when a FC link is down? We have a single path per controller, so if we loose that path everything goes down.
Thank you
1 REPLY 1
aborzenkov
Yes, it's possible. You need to connect host to both filer heads. There is no filer level failover when FC connection breaks - hosts at use supported multipathing software to handle it.
