ONTAP Hardware
Network Connections - LACP checking link choices
NIKSHERIDAN
Guys,
Anyone know a command to run on the netapp to show which port within an LACP bundle is being used to a given host?
My understanding (noob) is that the hashing is done on src/dst IP - can you confirm this with a command?
Many thanks!
Nik
1 REPLY 1
DAVE_WITHERS
The only thing I can suggest, is using ifgrp stat VIFNAME, to see which ports are being used, and and ifgrp status VIFNAME for other details.  I dont really think there is anyway to see what host is using which port unfortunately.  You will need to look switch/host side.
If someone has more info on this i'd be interested too as we run LACP to juniper ex4500s.
