ONTAP Hardware
on fas3250, what is maximum aggr size and maximum volume size?
netappmagic
Table 1) Maximum aggregate and FlexVol volume sizes.
FAS/V-Series
Platform
Maximum Aggregate Size (TB)
Maximum FlexVol Volume Size (TB)
6080, 6070
100
100
6040, 6030, 3170
70
70
3160, 3070, 3140, 3040
50
50
2040
30
30
similiar to this table?
1 ACCEPTED SOLUTION
MCARDINA221975
Maximum AGGR size is 105TB
Maximum FlexVol size is 70TB
You can find the 3250 technical specifications here:
http://www.netapp.com/us/products/storage-systems/fas3200/fas3200-tech-specs.aspx
Cheers!
-Mike-
1 REPLY 1
MCARDINA221975
Cheers!
-Mike-
