ONTAP Hardware
How does deduplication work if file/folder are renamed or compressed?
BILL12345
Hello,
As I undertand the FAS boxes do offer data dedeplication. We are wondering what happend with renamed files and/or folders?
Thank's a lot for any feedback!
Bill
2 REPLIES 2
aborzenkov
I do not expect that anything happens at all. File content does not change and remains in the same state it was before renaming.
BILL12345
Thanks for the feedback!
-> I do not expect that anything happens at all. File content does not change and remains in the same state it was before renaming.
Ok that sounds good 🙂
Is there a way to visualize all versions(even if they are renamed) of the object in question in a single timeline directly on the FAS box (e.g. in a browser)?
Thank you!
Bill
Nachricht wurde geändert durch: bill evergreen
