ONTAP Hardware
How to add DSMK14 FC Shelf to FAS2020
paragdahiwal
Hello,
Can anyone please let me know the procedure or installation steps to HOT ADD DSMK14 FC shelf to existing FAS2020 Box.
Given below are the parts ordered for the same...
Sl No
Part Number
Product
1
X6539-R6
SFP,Optical,4.25Gb,R6
2
X6536-R6
Cable,Cntlr-Shelf/Switch,5m,LC/LC,Op
3
X5515A-R6
Rackmount  Kit,4N2,DS14-Middle,R6
4
X553A-R5
DS14MK4,FC,wPSU,AC,R5
5
X800K-R6
Power Cable  India,South Africa,R6
6
X5512A-R5
ESH4 Module
7
X291A-R5
Disk  Drive,450GB 15k 4Gb FC,DS14
Thanks & Regards,
Parag
1 REPLY 1
dwaghmare
Assumptions -
1. Considering you FAS2020 currently not having any disk shelf connected.
2. FAS2020 is dual controller system
3. You have 1 FC port free for shelf connectivity
4. Free FC port on FAS2020 is in Initiator mode
Steps -
1. Rack mount disk shelf
2. Power on disk shelf
3. Check and verify all HDDs, power supplies and other components are green
4. Connect SFP modules in disk shelf ESH4 FC ports (In and Out)
5. Take LC-LC FC cables and connect between onboard FC ports and In port on disk shelves (one from each controller to ESH modules)
6. Check disk visibility to controllers by running disk show -n and then assign the disks to respective controller
7. Create required Aggregates --> Volumes
If you have existing DS14MK4 FC disk shelf, then you can add the new disk shelf in existing loop. You will need to power on new shelf and then connect FC cables from out port of last shelf in existing loop to in port of new shelf. You can have maximum 6 shelves per loop (best practices 4 )
Hope this helps...
