ONTAP Hardware
Info accessing FAS2040 from Konica Minolta C280
CARLOSOLINFO
I  my  enviroment is  a domain win2008 with AD
Users are able to access the share on FAS directly from pc
My C280 send scan to a share (pointing \\fas\share) using domain admin user but the scans fail to connect ....
Any idea?
Thank you in advance for your help, feel free to contact me for further info.
I'm asking to konica the same question.
Carlo
2 REPLIES 2
vmsjaak13
A month ago I experienced the same issue with a Ricoh multifunctional.
In the end it turned out that the MFP required that the Share Permissions were set to "Full controll" instead of "Change" and "Read".
Regards,
Niek
CARLOSOLINFO
It was a good idea ..  but the customer says that is not working.
Next week I will be "on palce"
Caro
