ONTAP Hardware
How to determine why FC-adapter got disabled
jenoptik
Hi there,
How can I determine the cause of a disabled fc-adapter?
This night the adapter has changed its state to disabled, why?
What errors/failures can occur if i enable the adapter again?
Which log is the right one?
Thx 4 any reply
1 ACCEPTED SOLUTION
jenoptik
Problem solved.
Checked EMS Log, Shelf_ESH Log
Look for fci and esh entries:
Wed Sep 2 22:07:15 CEST [n001020: fci.link.error:error]: Could not recover link on Fibre Channel adapter 0b after 30 seconds. Offlining the adapter
<esh_word_error_1
diskID="[IN] port"
channels="PARTNER/0b"
shelfID="1"
element="ESH A "
bay=" "
reason="reports invalid word error"/>
No connections between fc adapters.
possible reasons:
failed esh modul
failed sfp transceivers
Reason: failed sfp transceiver
After replacement of sfp transceiver the resync has started. Resync completed. Everythin is fine.
1 REPLY 1
jenoptik
Problem solved.
<esh_word_error_1
diskID="[IN] port"
shelfID="1"
element="ESH A "
bay=" "
possible reasons:
failed esh modul
