ONTAP Hardware
How to do a proper shutdown ?
BENCRPNETAPP
Hi,
I've read that the proper way to do a shutdown is to use the halt command. After I did so, I can still ping the BMC. Is it normal ? Can I go ahead and unplug the electrical power on my FAS now ? or do I have to do something to shutdown the BMC as well ?
Thanks
1 REPLY 1
RICCO4400
Hi Benoit
You can switch off  your FAS
Nothing to do
BMC is always available when there is power.
It allows you to start/stop FAS remotely
