ONTAP Hardware
Link not connected status on netapp FC Target adapter
SagarDH
Hi Team,
I need to present FCOE lun to initiator for testing purpose.
We have netapp 3140 running on 8.0.X 7 mode.
I have connected optical cable from Netapp FC Target Host Adapter 1b to Nexus 5010 Fc2/1. But link not coming up.
Belows is the Netapp side Module and FC card description:
slot 1: Fibre Channel Target Host Adapter 1b
                (Dual-channel, QLogic CNA 8112 (8152) rev. 2, <LINK NOT CONNECTED>)
                Firmware rev:     5.5.2
                Host Port Addr:   000000
                Cacheline size:   16
                SRAM parity:      Yes
                FC Nodename:      50:0a:09:80:89:2b:b8:31 (500a0980892bb831)
                FC Portname:      50:0a:09:82:99:2b:b8:31 (500a0982992bb831)
                Connection:       No link
  SFP Vendor Name:  FINISAR CORP.
  SFP Vendor P/N:   FTLX8571D3BCL-QL
  SFP Vendor Rev:   A
  SFP Serial No.:   AGS0A4K
  SFP Connector:    LC
  SFP Capabilities: 10 Gbit/Sec
                        I/O base 0x0000000000002c00, size 0x100
                        memory mapped I/O base 0xfca0c000, size 0x4000
                        memory mapped I/O base 0xfce00000, size 0x100000
Below is the Nexus 5010 port fc2/1
fc2/1 sfp is present
    Name is CISCO-FINISAR
    Manufacturer's part number is FTLF8524P2BNL-C2
    Revision is D
    Serial number is FNS140401NH
    FC Transmitter type is short wave laser w/o OFC (SN)
    FC Transmitter supports intermediate distance link length
    Transmission medium is multimode laser with 62.5 um aperture (M6)
    Supported speeds are - Min speed: 1000 Mb/s, Max speed: 4000 Mb/s
    Nominal bit rate is 4300 Mb/s
    Link length supported for 50/125mm fiber is 150 m
    Link length supported for 62.5/125mm fiber is 70 m
    Cisco extended id is unknown (0x0)
    No tx fault, no rx loss, no sync exists, diagnostic monitoring type is 0x68
    Digital diagnostics feature not supported in SFP
Please let me know is any configuration i need in Netapp side and cisco nexus side to bring link up or
Any modules not working or not compatabile.
Thanks in advance.
3 REPLIES 3
georgevj
please post the output of  "sysconfig -ac" "fcp status" and "fcp show adapter" commands.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
SagarDH
Hi George,
filer-4> sysconfig -ac
sysconfig: slot 1 OK: X1140A: QLogic ISP 8112; Dual Ported 8152 FCoE CNA Adapter (PCIe) Copper
sysconfig: slot 3 OK: X1107A: Chelsio S320E 2x10G NIC
sysconfig: System configuration meets block protocol requirements.
filer-4> fcp ststus
fcp: unrecognized command: "ststus".
The following commands are available; for more information
type "fcp help <command>"
config              ping                stats               topology
help                portname            status              wwpn-alias
nameserver          show                stop                zone
nodename            start
filer-4> fcp status
FCP service is running.
filer-4> fcp show adapter
Slot:                    1a
Description:             Fibre Channel Target Adapter 1a (Dual-channel, QLogic CNA 8112 (8152) rev. 2)
Adapter Type:            Local
Status:                  LINK NOT CONNECTED
FC Portname:             50:0a:09:81:99:2b:b8:31 (500a0981992bb831)
Standby:                 No
Slot:                    1b
Description:             Fibre Channel Target Adapter 1b (Dual-channel, QLogic CNA 8112 (8152) rev. 2)
Adapter Type:            Local
Standby:                 No
Slot:                    0d
Description:             Fibre Channel Target Adapter 0d (Dual-channel, QLogic 2432 (2462) rev. 2)
Adapter Type:            Local
FC Portname:             50:0a:09:83:99:2b:b8:31 (500a0983992bb831)
Standby:                 No
Thanks
andris
The cisco port's SFP is a 4GB FC SFP. FTLF8524P2BNL-C2
You wanted to have an FCoE link, yes? Then you need a 10GbE SFP.
