ONTAP Hardware
Maximum aggr size
pradkur
Whats the Maximum aggr size in 32-bit in FAS 2020
1 ACCEPTED SOLUTION
mbeattie
Hi,
Configuration maximums are based on controller model + ONTAP version. What version of dataONTAP is your controller running?
/matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
mbeattie
Hi,
/matt
hariprak
Hi,
FAS2020's maximum aggregate size is limited to (8TB). This limit is enforced by Data ONTAP 7.2.4L1, which restricts creation or expansion of an aggregate that is greater than (8TB) on FAS2020 systems.
Although the FAS2020 can effectively manage, address, and provide access to aggregates up to 16TB, the successful execution of WAFL recovery tools requires that FAS2020 aggregates be (8TB) or less.
For further more details refer KB article, https://kb.netapp.com/support/index?page=content&id=3012390&actp=search&viewlocale=en_US&searchid=1426744936085
Thanks
