ONTAP Hardware
Missing Java Classes for Filer At-A-Glance and others
mike_2
Trying to load Filer At-A-Glance and get the following.  I tried locating the actual
file it is trying to load, and it is not present on the filer.
SSL, TLS is enabled on the filer.
FAS3170, 7.3.4
This URL is not found:
https://<host>/na_admin/classes/com/netapp/meter/AtAGlance.class
Other things that require Java don't always work either.
https://<host>/na_admin/classes/com/netapp/admin/FilerHTTPConfigUIApplet/class.class
load: class com.netapp.meter.AtAGlance not found.
java.lang.ClassNotFoundException: com.netapp.meter.AtAGlance
    at sun.plugin2.applet.Applet2ClassLoader.findClass(Unknown Source)
    at sun.plugin2.applet.Plugin2ClassLoader.loadClass0(Unknown Source)
    at sun.plugin2.applet.Plugin2ClassLoader.loadClass(Unknown Source)
    at java.lang.ClassLoader.loadClass(Unknown Source)
    at sun.plugin2.applet.Plugin2ClassLoader.loadCode(Unknown Source)
    at sun.plugin2.applet.Plugin2Manager.createApplet(Unknown Source)
    at sun.plugin2.applet.Plugin2Manager$AppletExecutionRunnable.run(Unknown Source)
    at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException: open HTTP connection failed:https://<host>/na_admin/classes/com/netapp/meter/AtAGlance.class
    at sun.plugin2.applet.Applet2ClassLoader.getBytes(Unknown Source)
    at sun.plugin2.applet.Applet2ClassLoader.access$000(Unknown Source)
    at sun.plugin2.applet.Applet2ClassLoader$1.run(Unknown Source)
    at java.security.AccessController.doPrivileged(Native Method)
    ... 9 more
Exception: java.lang.ClassNotFoundException: com.netapp.meter.AtAGlance
1 REPLY 1
RAVI_PALADUGU
This will fix it for sure. I just tested on firefox and it works. Please follow this KB.
https://kb.netapp.com/support/index?page=content&id=2011730
Hope it helps.
Ravi
