ONTAP Hardware
Mixing disk sizes in stack
GRAEMEOGDEN
I know in the Storage Subsystem FAQ the recommendation is only to have a single transition between disk types or IOM modules in a stack.
Does this also apply to disk sizes? For example, would the following configuration be supported?
DS4243 3TB SATA
DS4243 1TB SATA
DS4243 1TB SATA
DS4243 3TB SATA
Thanks
Graeme
1 ACCEPTED SOLUTION
resqme914
You are fine to mix disk sizes in a shelf and stack.
1 REPLY 1
resqme914
