ONTAP Hardware
Max number of shelves in a stack
D_BEREZENKO
1 ACCEPTED SOLUTION
warrenb
Hi Dmitry,
It is the third column, here is a better image which shows the column headers : -
Regards,
Warren
8 REPLIES 8
warrenb
It is a little cryptic, but you need to go to http://hwu.netapp.com/Controller/Index and select your version of ONTAP and the controller model. After you click the Show Results button there will be a link labelled "Compatible Shelves/Drives" which will contain all the information you need.
As a general rule it is 10 shelves per stack, but there are limitations when using the low end controllers and/or SSD.
Regards,
Warren
D_BEREZENKO
HWU as you've just told not providing such an information. But Storage Subsystem Technical FAQ does.
warrenb
Hi Dmitry,
As I said, it is a little cryptic, but the information is there. See the following screen shot from Hardware Universe: -
Regards,
Warren
D_BEREZENKO
And where is the max number of shelves in a stack on the picture?
warrenb
Hi Dmitry,
Regards,
Warren
D_BEREZENKO
Thanks for your help!
radek_kubka
You can also find this info in Storage Subsystem Technical FAQ
D_BEREZENKO
Thanks!
