ONTAP Hardware
Module X60130A with 2 ports, one for Optical and one port for copper .
SrinivasaReddyAllu
we have AFFA50 We have IO Module X60130A with 2 ports ,Out of 2 ports does one port can be used for  Optical  with transreceiver and and other for Ethernet(Copper) .
We are planning to use one port for storage and one port for Data as part of Dual NIC
does it supports.
1 ACCEPTED SOLUTION
chamfer
Hi @SrinivasaReddyAllu ,
  • How many disk shelves do you have?
  • Are you using switched storage or switchless storage?
  • Do you have a single NIC or dual NIC (X60130A )?
  1. If you have 1x shelf and single NIC switched or switchless storage then you have no ports free as you will cable as per the attached image to ports e3a and e3b.
  2. If you have 2x shelf and dual NIC switchless then you have no ports free.
  3. If you have 1x shelf and dual NIC then you would have free ports on each card that you can mix optical (AOC + transceiver) and copper (DAC).
  4. If you have >2x shelf and dual NIC and switched storage, then you would have free ports on each card that you can mix optical (AOC + transceiver) and copper (DAC).
For those who find this post the best place to start in the future to answer your own hardware questions, is NetApp Hardware University (HWU) https://hwu.netapp.com/
Here is a direct link for the card https://hwu.netapp.com/Adapter/Index?category=36448154,21250,14241298&partno=X60130A#
This card is a QSFP28 card and will support:
  • copper Ethernet at 40 or 100Gbps via DAC (Direct Attached Copper); OR
  • optical Ethernet at 40 with transceiver and 100Gbps via both AOC (Active Optical Cable) and transceiver.
If you view "Support Connections" on the array you can see the combinations..... direct link here https://hwu.netapp.com/DetailViews/OverviewPage.aspx?platformTypeId=5265148&platform=34446844&os=48437980#
3 REPLIES 3
chamfer
SrinivasaReddyAllu
Hi
Thank s for the update .
It’s a Single disk shelf ,we have Same NIC X60130A in slot 01 and 03,In slot 01 we have used a Transceiver for Data network and Slot 03 for Storage connectivity .
We are going to use one port for storage on slot01 and one port from slot03 and we are using on port from slot 1 with transceiver for data and one port from slot03
E1b and e3a for storage and e1a and e3b for Data network .
Regards
SrinivasaReddy Allu
Professional Services Consultant – Keystone
NetApp
[email protected]
+91 (0) 7829343122 Mobile Phone
[A logo with a white square on it Description automatically generated with medium confidence]  
[A black circle with white letters Description automatically generated]   [A black and white logo Description automatically generated]    [A black and white logo Description automatically generated]    [A black circle with a white play button Description automatically generated]    [A black circle with white letters in it Description automatically generated]    [A black circle with white x in it Description automatically generated]    [A black circle with white logo Description automatically generated]  
 “We’re committed to providing our customers with the best products and services. Scan the QR code or click this link<> to provide your feedback. All responses will be anonymous and kept confidential. Thank you!”
andris
That configuration is supported.
Each port on these cards can be independently configured in terms of port speeds, transceivers and cables.
