ONTAP Hardware
Moving Boot Volume to Different Aggregate
kevinstay
Could someone point me to a procedure for moving the boot volume to another aggregate? (Is it simply the same as moving to another volume on the same aggregate?) I found this http://now.netapp.com/NOW/knowledge/docs/ontap/rel73_vs/html/v-series/ig_disk/move-sh2.htm so it seems doable. There is the option for root aggr as well, but we are warned not to change that without implicit instructions to do so.
1 REPLY 1
rmatt
There's a procedure for moving the root volume on a V-Series platform here:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel73_vs/html/v-series/ig_disk/moveroot.htm
It comes from the same manual you were looking at as a reference.
Is this what you were looking for? Also, are you using a V-Series platform or traditional NetApp controller?
