ONTAP Hardware
Need to replace X1167A-C FC NIC with X1169A-C i n FAS2820A
PKSharma
Hi ,
we need to replace X1167A-C FC Card  FC Only(wrongly Dispatched)  in FAS 2820A  with X1169A-C , UTA2 FC & iSCSI both . should i need to follow standard procedder to replace it or is there any different document that need to follow .
I have no issue in replacing exiting card , just want know if is the same process for diffrent card .
Please suggest and share therequired document.
3 REPLIES 3
cedric_renauld
Hello,
Have you already setup the cluster ?
PKSharma
Hello,
yes , but there is no data and as of now ,not in production . we canclear configuration if it is required.
cedric_renauld
It's not mandatory
You can change your card and redo your network / SAN configuraiton
