ONTAP Hardware
NetApp 7 mode Decommissioning
sakshee12
Hello All,
Can anyone help me with step wise Netapp 7 modde decommissioning. ?
1 REPLY 1
andris
If you are referring to the way to inform NetApp of the decommissioned system:
  1. Log in to the NetApp Support site (https://mysupport.netapp.com)
  2. Select "My Products"
  3. Search for the system to decommission in "View Installed Systems"
  4. From the pull-down menu of the "Product Tool Set" column for the system, select "Decommission this System".
