ONTAP Hardware
NetApp Newbie
NIKSHERIDAN
Hi Chaps,
I am a complete newbie.  A project has just gone into implementation: UCS/NetApp/VMware is being used, and the keys will be handed over to us soon for support and operations.  Can anyone suggest any recommended reading or have any advice for a newbie?
Many thanks,
Nik
6 REPLIES 6
jacint_juhasz
hi,
I think the NetApp vSphere best practices is a quite readable document:
http://media.netapp.com/documents/tr-3749.pdf
also there is a basic concepts quick start guide (bit old, but still good):
http://communities.netapp.com/docs/DOC-2999
regards,
Jacint
http://tt.yyaazz.hu
radek_kubka
Hi and welcome to the Community!
Well, looking at the key components of your solution I am thinking that maybe some reading about FlexPod would be useful?
http://www.netapp.com/us/library/technical-reports/tr-3884.html
http://www.cisco.com/en/US/docs/solutions/Enterprise/Data_Center/Virtualization/flexpod_vmware.html
There are tons of material about NetApp best practices, but probably the already mentioned doc about vSphere is the most relevant & could be a good starting point.
Regards,
Radek
[Can a moderator move this thread to a slightly more relevant place? Shared IT Infrastructure?]
NIKSHERIDAN
Hi!
Thanks all for the posting!  I am going to cram this in and no doubt, will end up with endless further questions!!!
Many thanks,
Nik
peluso
Moving to Shared IT Infrastructure - thanks Radek!
Thanks so much!
Terri Peluso
Senior Community Program Manager
garcia
You might also want to take a look at the FlexPod for VMware Validated Design, just search FlexPod in communities or in NOW (or Google !)  It uses Cisco UCS B servers, Nexus 5K switches and NetApp FAS controllers.  If that's like the kit you have, we have step by step application deployment guides, sizing information and a whole network of partners who are trained on the solution.  There may be some additional value for you.
Gary
NIKSHERIDAN
Thanks,  really similar to flexpod less the Nexus5k's
