ONTAP Hardware
NetApp SED drives
phamq
Is it possible to still use SED drives without the encryption server? Basically ordered disk shelves with them and didn't know that the wrong 600GB drives were order.  But I was told that was the only 600GB drives they had left. I just need to know if I'm still good to use them.
1 ACCEPTED SOLUTION
radek_kubka
You cannot mix SED and non-SED drives in the same system.
2 REPLIES 2
radek_kubka
phamq
Got it, thanks.
