ONTAP Hardware
NetApp Storage Disk Shelf. DS212C SATA disk shelf with 12 X 4TB SATA to NetApp FAS8200 & FAS8020
KRT
Hello Experts;
Hope you are all well and in good health? I have a few questions i kindly request for your expertises.
Qns 1:
When assigning ownership to Disk of DS212C of 4TB only 8disks are assigned 4 disk become shared and I can't use them for creation of aggregates
Qns 2:
Is there a way of forcing these 4 disks to be owned by single controller so that I can use them.
Kindly assist me with solutions to these challenges. Thanks alot for your help
1 ACCEPTED SOLUTION
pedro_rocha
Hello,
I do not see why you wouldn't be able to use those disks in the way you want. It seems they are partitioned. These are new/unused shelves, right?
Can you share the output for the below commands?
storage disk show -ownership
storage disk show -partition-ownership
If they are partitioned, you should be able to remove the partitions with the following command:
system node run -node xxx -command disk unpartition xx.xx.xx
or
set d
storage disk unpartition ....
Kind regards,
Pedro
2 REPLIES 2
pedro_rocha
Hello,
or
set d
Kind regards,
Pedro
junwang
Hi,KRT
If the hard disk status is shared, it means that these disks have been partitioned and used. If you want to allocate these disks to a node for use, you need to first unpartitione and then reassign them to the same node for use.
Use the following command to view.
The command to partition is as follows
Or enter node mode to perform split area command
disk unpartition disk_list xx.xx.xx
