ONTAP Hardware
Aggregate aggr0 (failed, raid_dp, partial) (block checksums)
eliebeskint
im new on netapp and i found this error below , how can we fix it ?
you r help is really appreciated
  Plex /aggr0/plex0 (offline, failed, inactive)
    RAID group /aggr0/plex0/rg0 (partial)
      RAID Disk Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
      dparity   0a.16   0a    1   0   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      parity    0a.45   0a    2   13  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.32   0a    2   0   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.33   0a    2   1   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      FAILED          N/A                   136000/278528000
      data      0a.35   0a    2   3   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.29   0a    1   13  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.20   0a    1   4   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.36   0a    2   4   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.37   0a    2   5   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.22   0a    1   6   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.38   0a    2   6   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.23   0a    1   7   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.39   0a    2   7   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.24   0a    1   8   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.40   0a    2   8   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.25   0a    1   9   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.41   0a    2   9   FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.26   0a    1   10  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.17   0a    1   1   FC:A   -  FCAL 10000 136000/278528000  280104/573653840
      data      0a.27   0a    1   11  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.43   0a    2   11  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      data      0a.44   0a    2   12  FC:A   -  FCAL 15000 136000/278528000  137104/280790184
      Raid group is missing 4 disks.
Spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           0a.18   0a    1   2   FC:A   -  FCAL 15000 136000/278528000  137104/280790184 (not zeroed)
spare           0a.19   0a    1   3   FC:A   -  FCAL 15000 136000/278528000  137104/280790184 (not zeroed)
spare           0a.21   0a    1   5   FC:A   -  FCAL 15000 136000/278528000  137104/280790184 (not zeroed)
spare           0a.34   0a    2   2   FC:A   -  FCAL 15000 136000/278528000  137104/280790184 (not zeroed)
spare           0a.42   0a    2   10  FC:A   -  FCAL 15000 136000/278528000  137104/280790184 (not zeroed)
spare           0a.28   0a    1   12  FC:A   -  FCAL 15000 136000/278528000  137422/281442144 (not zeroed)
4 REPLIES 4
aborzenkov
@eliebeskint wrote:
how can we fix it ?
If disks really failed - you cannot (without data loss). It is impossible to recover raid group with 4 failed disks, so the only option is to recreate aggregate and restore data from backup.
To determine whether disks are really failed you should open support case to analyze your system.
eliebeskint
thanks for your reply , how i can check if i have a backup , is there any command i can run it ?
paul_stejskal
No that would mean a backup of your data.
You might be able to open a case with us and we can try to help us support the system.
junwang
Hi,eliebeskint,
There are more than 2 bad disks in an aggregation, causing RAID damage. There are currently 6 spare disks, but their status is not zeroed. In this state, spare disks will not be used. The solution is to zero the spare disk.
::> disk zerospares
After zero is completed, the system will automatically write the data of the faulty disk to the spare disk. After all disks are synchronized to the spare disk, normal operation can be restored. Then, replace the broken disk.
