ONTAP Hardware
Netapp FAS8020 I CAN PING ONE SUB INTERFACE BUT NOT THE OTHERS ....???
fonoconn
Hello,
   we are having an issue with our FAS, so we setup a virtual interface group (a0a) and we have vlans under it a0a-31, a0a-204, a0a-304,a0a-80
  I can ping  a0a-31 but none of the others, where do i start to trouble shoot this ? we ahve double checked our switch configs adn everything.
2 REPLIES 2
Anoop
Hi,
You may want to check if your storage is configured as per the best practices below:
http://www.netapp.com/us/media/tr-3802.pdf
You may also want to try the following KBs:
https://kb.netapp.com/support/index?page=content&id=1011533
https://kb.netapp.com/support/index?page=content&id=1012777
Regards,
Anoop B A
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Naveenkumarp22
Hi
Please mention type of the VIF. We need some more information. If you don't mind can you please post the below commands.
Vlan stat
vif status or ifgrp status
