ONTAP Hardware
Partner Disk FAS 2040
syedkhan
Hello,
      We have Single FAS 2040 on our Disaster recovery site which we use it for snapmirror. Last few dasy back we installed a new hard drive but unfortunately its detected as a prtner instead of unowned. I know in high availibilty env partner is used.
and also if I see from the Command Line using disk show -v
Netappdr> disk show -v
DISK OWNER POOL SERIAL NUMBER HOME
0d.01.0 Netappdr (142258223) Pool0 YHHXR5EA Netappdr (142258223)
0d.01.11 Netappdr (142258223) Pool0 YHGYW50A Netappdr (142258223)
0d.01.8 Netappdr (142258223) Pool0 YHGYZLXA Netappdr (142258223)
0d.01.9 Netappdr (142258223) Pool0 YHGYW4VA Netappdr (142258223)
0d.01.5 Netappdr (142258223) Pool0 YHGYWYBA Netappdr (142258223)
0d.01.7 Netappdr (142258223) Pool0 YHGYVURA Netappdr (142258223)
0d.01.2 Netappdr (142258223) Pool0 YHGYYZPA Netappdr (142258223)
0d.01.10 Netappdr (142258223) Pool0 YHGYX1RA Netappdr (142258223)
0d.01.4 Netappdr (142258223) Pool0 YHGZ0KRA Netappdr (142258223)
0d.01.3 Netappdr (142258223) Pool0 YHGYX7MA Netappdr (142258223)
0d.01.6 Netappdr (142258223) Pool0 YHGYW49A Netappdr (142258223)
0d.01.1 Netappdr (142258223) Pool0 YHGYWSAA Netappdr (142258223)
0d.01.12 netappctrl1(1574746261) Pool0 Z29394KM netappctrl1(1574746261)
I need to netapp ctrl1 is located in the Head office and why its detecting directly ? I need it to remove from Netappctrl1 to locally which is netappdr
1 ACCEPTED SOLUTION
Anoop
Hi,
The correct procedure can be found below:
https://kb.netapp.com/support/index?page=content&id=1015293
https://library.netapp.com/ecmdocs/ECMP1511539/html/storage/disk/assign.html
Hope this helps.
Regards,
Anoop
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
3 REPLIES 3
syedkhan
It worked this way just need your inputs if its correct
disk assign 0d.01.12 -s unowned -f
it went to unowned
then added to aggregate
Anoop
Hi,
Hope this helps.
Regards,
Anoop
Naveenkumarp22
You can use the below command.
Netappcntrl1  : priv set advanced
Netappcntrl1 *: disk remove_ownership 0d.01.12
Netappcntrl1 *: priv set admin
Netappcntrl1 : disk show -n
log in to Netappdr
Netappdr : disk assign 0d.01.12
