ONTAP Hardware
Netapps newbie
nssnetwork
Our department will be deploying some NetApp V-Serie 3100. We will use LACP to aggregate some interfaces  (2 x 2Gig) on the appliances onto to  2 Cisco 4500 Catalyst switches. Does a network loop could be created if the NetApp appliance is not configured properly
Thanks
Dr-Gilles
1 REPLY 1
BrendonHiggins
Hi, welcome to the community.
Have a look at VIF and LACP on the now site.  Here is a good link to get you started.
https://now.netapp.com/Knowledgebase/solutionarea.asp?id=kb20148
Hope it helps
Bren
PS - We just used single mode VIFS as it is good enough for us and is much simpler.
