ONTAP Hardware
Network Configuration Checker and route add
sg_infomatik
Hi, I have a FAS2240-2 on which the network configuration checker complains about /etc/rc and /etc/hosts mismatch. I looks like this:
My /etc/rc and /etc/hosts look like this:
chgsto01> rdfile /etc/rc
hostname chgsto01
ifgrp create lacp ifgrp01g -b ip e0a e0b e0c e0d
vlan create ifgrp01g 1724 1725 1726
ifconfig ifgrp01g-1724 `hostname`-ifgrp01g-1724 netmask 255.255.255.240 mtusize 1500 #NFS Network
ifconfig ifgrp01g-1724 alias `hostname`-ifgrp01g-1724-alias netmask 255.255.255.240 #NFS Network alias
ifconfig ifgrp01g-1725 `hostname`-ifgrp01g-1725 netmask 255.255.255.240 mtusize 1500 #ISCSI Network
ifconfig ifgrp01g-1726 `hostname`-ifgrp01g-1726 netmask 255.255.255.240 mtusize 1500 #CIFS Network
ifconfig e0M `hostname`-e0M netmask 255.255.255.0 mtusize 1500 #MGMT Network
route add default 172.27.133.1 10
route add net 172.27.224.0/19 172.27.241.81 1
routed off
savecore
chgsto01> rdfile /etc/hosts
127.0.0.1 localhost localhost-stack
127.0.10.1 localhost-10 localhost-bsd
127.0.20.1 localhost-20 localhost-sk
172.27.241.94 chgsto01 chgsto01-ifgrp01g-1726 #CIFS Network
172.27.241.62 chgsto01-ifgrp01g-1724 #NFS Network
172.27.241.61 chgsto01-ifgrp01g-1724-alias #NFS Network alias
172.27.241.78 chgsto01-ifgrp01g-1725 #ISCSI Network
172.27.133.5      chgsto01-e0M #MGMT Network
chgsto01>
In my opinion all interfaces are described in the /etc/hosts file and the route 172.27.224.0/19 goes out of the interface chgsto01-ifgrp01g-1726 to the gateway 172.27.241.81. Do I have to specify the route differently (i.e. route add net 172.27.224.0/19 172.27.241.94 1) pointing to the local interface? This way I depend on the router to proxy the ARP requests of the FAS2240-2.
Any hint is appreciated.
2 REPLIES 2
247itsupport
Hi Peter,
Were you ever able to resolve the mismatch as we are experiencing the exact same error?
Thanks,
Mark
henri_mahe
For peter :
not the dot 0
route add net 172.27.224/19 172.27.241.81 1
For Mark :
not the dot 0
route add net 172.20.240/24 10.5.24.250 1
