ONTAP Hardware
Network attach servers to AFF A-Series
RS232
Can you Network attach a couple of ESXi servers directly, for iSCSI, to an AFF A-Series array?
1 ACCEPTED SOLUTION
AlexDawson
Direct attachment for iSCSI only is supported - please review this document starting on page 35 - https://docs.netapp.com/us-en/ontap/pdfs/sidebar/SAN_configuration_reference.pdf
If you have any other choice, using two switches is a better idea from a management and survivability standpoint.
Thanks!
2 REPLIES 2
cedric_renauld
Hello,
Little question : iSCSI connexion are fibre, DAC or Rj45 ?
Thanks
AlexDawson
Thanks!
