ONTAP Hardware
Low on spare disk
PeterMe
Hi,
I have a FAS2720 with 9 disks, all assigned to one node.
I created one aggregate with 8 disks, 1 disk as spare.
In the eventlog I see warnings like this:
Call home for SPARES_LOW: /aggr1_aef_st3_n1/plex0/rg0, /aggr0_AEF_ST03_01/plex0/rg0
There are not enough spare disks. Assign unowned disks
Output from: storage aggregate show-spare-disks
Original Owner: aef-st3-n1
Pool0
Root-Data Partitioned Spares
Local Local
Data Root Physical
Disk Type Class RPM Checksum Usable Usable Size Status
1.0.4 FSAS capacity 7200 block 3.54TB 93.52GB 3.64TB zeroed
How do I avoid the warnings about LOW Spares ?
Thanks
1 ACCEPTED SOLUTION
Ontapforrum
Please check this kb:
How to disable SPARES_LOW AutoSupport notifications:
https://kb.netapp.com/onprem/ontap/os/How_to_avoid_regular_notification_of_ASUPs_SPARES_LOW
Please Note: When you add partitioned disks to an aggregate, you must leave a disk with both the root and data partition available as spare for every node. If you do not and your node experiences a disruption, ONTAP cannot dump the core to the spare data partition.
To set raid.min_spare_count option to 0 with the following command: (To stop SPARES_LOW warnings)
::> storage raid-options modify -node <node_name> -name raid.min_spare_count -value 0
1 REPLY 1
Ontapforrum
