ONTAP Hardware
No Disk after Disk Replacement (FAS3020)
jenoptik
Hi everybody,
After a disk replacement in one of our FAS3020 (DS14-Mk2-AT) I suppose the disk is not well replaced.
We have 14 disks in this ATA Shelf and 13 disk of these in one raidgroup + 1 spare disk.
The only message I got was the following:
Mon Aug 31 16:00:52 CEST [n001010: raid.disk.missing:info]: Disk 2a.20 Shelf 1 Bay 4 [NETAPP   X267_SMOOST50SSX NA01] S/N [9QMBSTRG] is missing from the system
Is there a success message, after a disk replace was done?
OnCommand tells me 13 disk are in the raidgroup (so the aggr is still working) but i cant see a spare anymore.
How can I determine, whether the replacement was successfull or not?
Ho do I know whether the new disk was connected or the backplane/shelf-slot has seen a new disk?
Thx for your help
1 ACCEPTED SOLUTION
jenoptik
Argh.... don't tell anyone that our technical assistent hasn't seen the replaced disk doesn't have the right size..... seems SOLVED
1 REPLY 1
jenoptik
