ONTAP Hardware
Not able to detect the Tape Drives & Changer in FAS3250 (ONTAP 8.1.3 7 Mode)
BHAVEN2420
Hi All,
I have zoned NetApp FC adapter and assigned VTL/drives to it however I am not able to detect it on NetApp.  Can someone point out what is going wrong?
etc$\tape_config folder has the TCF file for IBM LTO 3 drives.
Here is the info on assigned VTL MC (L180)  and Drives (IBM LTO 3)
-- I can see Netapp port login on DataDomain
NETAPP01_0c   NETAPP01_0c              Online   50:0a:09:80:03:56:8e:d8   50:0a:09:80:03:56:8e:d8   0a
                                       Online   50:0a:09:80:03:56:8e:d8   50:0a:09:80:03:56:8e:d8   0b
-- Assigned the VTL/drives to the above HBA card of NetApp
Group: NETAPP01_0c
Initiators:
Initiator Alias   Initiator WWPN
NETAPP01_0c    50:0a:09:80:03:56:8e:d8
Devices:
Device Name                      LUN   Primary Ports   Secondary Ports   In-use Ports
NETAPP01VTL01 changer      0              0a              none             0a
NETAPP01VTL01 drive 1      1              0a              none             0a
NETAPP01VTL01 drive 2      2              0a              none             0a
NETAPP01VTL01 drive 3      3              0a              none             0a
NETAPP01VTL01 drive 4      4              0a              none             0a
NETAPP01VTL01 drive 5      5              0a              none             0a
NETAPP01VTL01 drive 6      6              0a              none             0a
NETAPP01VTL01 drive 7      7              0a              none             0a
NETAPP01VTL01 drive 8      8              0a              none             0a
NETAPP01VTL01 drive 9      9              0a              none             0a
NETAPP01VTL01 drive 10    10              0a              none             0a
Slot:            0c
Description:     Fibre Channel Host Adapter 0c (QLogic 2432 rev. 2)
Firmware Rev:    5.4.100
FC Node Name:    5:00a:098003:568ed8
FC Port Name:    5:00a:098003:568ed8
FC Packet Size:  2048
Link Data Rate:  4 Gbit
SRAM Parity:     Yes
External GBIC:   No
State:           Enabled
In Use:          Yes
Redundant:       No
NETAPP01> fcadmin config
                  Local
Adapter Type      State                  Status
  0c   initiator  CONFIGURED.            online
  0d   initiator  CONFIGURED.            online
(( disabled the SAN switch port where 0c is connected ))
NETAPP01> Tue Jun 24 12:05:15 SGT [NETAPP01:fci.link.break:error]: Link break detected on Fibre Channel adapter 0c.
Tue Jun 24 12:05:46 SGT [NETAPP01:fci.link.error:error]: Could not recover link on Fibre Channel adapter 0c after 30 seconds. Offlining the adapter.
NETAPP01>  ndmpd status
ndmpd OFF.
No ndmpd sessions active.
NETAPP01>  ndmpd on
NETAPP01>
NETAPP01> ndmpd version
ndmpd highest version set to: 4
NETAPP01>
NETAPP01> date
Tue Jun 24 12:08:21 SGT 2014
(( enabled the SAN switch port where 0c is connected ))
NETAPP01> Tue Jun 24 12:08:34 SGT [NETAPP01:fci.adapter.link.online:info]: Fibre Channel adapter 0c link online.
Tue Jun 24 12:08:34 SGT [NETAPP01:fci.adapter.online:info]: Fibre Channel adapter 0c is now online.
NETAPP01> sysconfig -m
No medium changers present on system.
NETAPP01> sysconfig -t
No tape drives present on system.
NETAPP01>
1 REPLY 1
D_SITTA_SINERGY
excuse me did you resolve the issue? We also have this problem wit fas3250 7-mode 8.1.4 Metro cluster. After every powercycle of the Quantum I40 tape library zoned in SAN with the filer on port 3c (Initiator) , then sysconfig -t show the tape drives correctly but sysconfig -m or storage show mc output "No medium changer present on the system"
NetApp & brocade help us in trobleshooting changing Tape library from Loop , Auto NL Auto LN and Point to Point in SAN, we also changed the tape drive & upgraded Qauntum I40 firmware but always the same issue. Changing FC patch cable & SAN switch port does not resolve the issu. We are still investigating.
if we do a set of this command on both the filers the it works: but why before dataontap upgrade we did'not have this issue?
storage disable adapter 3c
storage enalbe adapter 3c
and the sysconfig -m show the media changer.
Thanks
