ONTAP Hardware
DIMM replacement guide for FAS 8000 Series
newbeee
Hi fellow ,
any steps to follow ?
currently there are two controller(HA) one controller DIMM has reached end of life, which is leading to
                     memory error messages.
before doing the physically dimm replacement, the controller need to take over the partner first .
any proper procedure to follow?
Thanks
1 REPLY 1
Harry_Redl
Hello,
for parts replacement check the Documentation section in the support.netapp.com - for DIMMs and FAS8xxx see
https://library.netapp.com/ecm/ecm_download_file/ECMP1199899
Harry
