ONTAP Hardware
OCUM : format reports exported to PDF
GrumpyOldMen
I have created a customized report in OCUM and wanted to export it to PDF. So far so good no problems. But when I open the PDF it is barely readable. Is there a way to format the output?
Or is their a way to easely receive a report of just the used capacity for the different volumes belonging to the different SVM's?
2 REPLIES 2
AlainTansi
Hi,
What version of OCUM are you using ?
Have you tried exporting the reports in other formats like Excel or XHTML and its still unreadable ?
Not sure if my screenshot is visible, but have you tried this option ?
GrumpyOldMen
I did try multiple reports. But the problem is that the PDF is the only report that can be directly opened in the mail. For the others I still have to format the output. The XHTML is also decent report but you have to click multiple times in mail. Not that I have a problem with it, but it is not very nice for customers.... 😞
