ONTAP Hardware
Performance difference between X357A-R6 vs X356A-R6 disks
Maurice-FreeOnes
Hello,
Can somebody explain to me the performance difference between X357A-R6 vs X356A-R6 disks?
thank you very much!
Regards, Maurice
4 REPLIES 4
SpindleNinja
hwu.netapp.com is your friend!
Part Number Type Marketing Capacity Physical Right-Sized Encrypted RPM Checksum Interface Speed EOA EOS
X356A-R6 SSD 3840 GB 3576 GiB 3576 GiB no   BCS 12 Gbps, 3 Gbps, 6 Gbps 09-Dec-2019 31-Jan-2025
X357A SSD 3840 GB 3576 GiB 3576 GiB no   BCS 12 Gbps, 6 Gbps
paul_stejskal
I believe the 356 is older and it supports the older 3Gb/s SAS shelves according to HWU. It may have the 3.5" enclosure too or an adapter for it I'm not sure. But the 356 is listed to support the 3Gb shelves but the 357 is not. Probably exact same SSD otherwise.
If you're ordering a new one, 357 would probably be what you need.
SpindleNinja
the 356 is also EOA
Maurice-FreeOnes
Hi everybody,
Yes I know about HWU. Sorry for not asking it right.
When I look on Ebay there is a big difference is pricing of these 2 models. The new one is about 2-3 times more expensive.
That's what made me think there must be differences in speed between the 2 models. Since the X357A is a new one I tried to find test reports, but couldn't find anything thru Google.
Regards, Maurice
