ONTAP Hardware
Part Number Information 10GB SFP QBic for FAS6280 controller
ferianto_siregar85
Dear All experts,
I have installed 2 FAS6280 controllers which are connected using cluster each other.
For Network connection, I plan to use 10GB Ethernet. While running sysconfig -v, I got information bellow:
slot 0: 10 Gigabit Ethernet Controller IX1-SFP+
                 e0c MAC Address:    00:a0:98:2d:2a:cf (auto-unknown-down)
                 e0d MAC Address:    00:a0:98:2d:2a:ce (auto-unknown-down)
                 e0e MAC Address:    00:a0:98:2d:2a:d1 (auto-unknown-down)
                 e0f MAC Address:    00:a0:98:2d:2a:d0 (auto-unknown-down)
                 Device Type:        82599
It is on board port, but I can not find the SFP module for this slot coming with the delivery packing list. I think I have to buy it. Does anyone know the P/N (Part Number) for 10GB SFP QBic that I must buy for this slot, please?
Thank you for help
regards,
--ferianto--
2 REPLIES 2
scottgelb
The onboard are not included by default and a check box needs to be selected for a new system. For these ports use the x6589-r6. This isn't compatible with the pcie nics and only the onboard.
ferianto_siregar85
Thank you Scott...I will go further for asking the module price to NetApp...
Thank you for your help..
HAPPY NEW YEAR...
regards,
--feri--
