ONTAP Hardware
Powersupply Error
VenkateshChennai
Channel: 0a
        Shelf: 12
        SES device path: local access: 3a.12.99
        Module type: IOM3; monitoring is active
        Shelf status: unrecoverable condition
        SES Configuration, shelf 12:
         logical identifier=0x50050cc102019c11
         vendor identification=NETAPP
         product identification=DS4243
         product revision level=0211
        Vendor-specific information:
         Product Serial Number: SHU0954292N08CS
        Status reads attempted: 4151217; failed: 0
        Control writes attempted: 0; failed: 0
        Shelf bays with disk devices installed:
          23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0
          with error: none
        Power Supply installed element list: 1, 2, 3, 4; with error: 1
        Power Supply information by element:
          [1] Serial number: PMW82562005794C  Part number: 0082562-12
              Type: 9C
              Firmware version: 0311  Swaps: 0
          [2] Serial number: PMW82562005791D  Part number: 0082562-12
              Type: 9C
          [3] Serial number: PMW82562005793B  Part number: 0082562-12
              Type: 9C
          [4] Serial number: PMW825620057946  Part number: 0082562-12
              Type: 9C
        Voltage Sensor installed element list: 1, 3, 4, 5, 6, 7, 8; with error: none
        Shelf voltages by element:
          [1] 3.05 Volts  Normal voltage range
          [2] Unavailable
          [3] 5.01 Volts  Normal voltage range
          [4] 12.02 Volts  Normal voltage range
          [5] 5.01 Volts  Normal voltage range
          [6] 12.02 Volts  Normal voltage range
          [7] 5.01 Volts  Normal voltage range
          [8] 12.03 Volts  Normal voltage range
        Current Sensor installed element list: 1, 2, 3, 4, 5, 6, 7, 8; with error: none
        Shelf currents by element:
          [1] 660 mA  Normal current range
          [2] 540 mA  Normal current range
          [3] 4600 mA  Normal current range
          [4] 6750 mA  Normal current range
          [5] 3320 mA  Normal current range
          [6] 9680 mA  Normal current range
          [7] 3080 mA  Normal current range
          [8] 6950 mA  Normal current range
Powersupply shows with error: 1.
System has 4nos power supplies. How many Powersupply failure does this Shelf can withstand. If so in what order.
Please explain how redundancy is planned in Powersupply
Thank you
2 REPLIES 2
Jeff_Yao
for 4 PSUs DS4243, your filer should be able to withstand 2 faulted PSUs. position doesnt matter. but pls replace the faulted one asap.
VenkateshChennai
Thanks for the Info, we had arranged for replacement and it is compled
Thanks again
