ONTAP Hardware
Problem with agregate free space and snapmirroring
PASCAL_78
Hello everybody.
I've got 2 FAS 2220 with 8.1.1 7-mode.
I activated asynchronous snapmirroring (on nfs_logs) , and it's working fine, but I can see that agregate free space is going down.
The first time (before snapmirroring), the output was like it:
aggr show_space -h
Aggregate 'aggr0'
    Total space    WAFL reserve    Snap reserve    Usable space       BSR NVLOG           A-SIS          Smtape
           24TB          2479GB             0KB            21TB             0KB             0KB             0KB
Space allocated to volumes in the aggregate
Volume                          Allocated            Used       Guarantee
vol0                                173GB          4258MB          volume
nfs_logs                             21TB           105MB          volume
Aggregate                       Allocated            Used           Avail
Total space                          21TB          4363MB           626GB
Snap reserve                          0KB            0KB             0KB
WAFL reserve                       2479GB            18GB          2460GB
Now :
aggr show_space -h
Aggregate 'aggr0'
vol0                                173GB          4653MB          volume
nfs_logs                             21TB          8425MB          volume
Total space                          21TB            12GB           614GB
Snap reserve                          0KB            11GB             0KB
I dont't understand why snap reserve is growing, because agregate scheduling isn't working:
snap sched -A
Aggregate aggr0: 0 0 0
Thanks
1 ACCEPTED SOLUTION
PASCAL_78
All is ok now, no more agregate snapshots arre generated.
Thanks you Said.
8 REPLIES 8
LTDCLSERGAO
Hello,
Could you give ; df  -Ah and snap list -A
PASCAL_78
Hello Said,  this is the output:
df -Ah
Aggregate                total       used      avail capacity
aggr0                     21TB       21TB      614GB      97%
aggr0/.snapshot            0GB       11GB        0GB     ---%
and :
snap list -A
Aggregate aggr0
working...
  %/used       %/total  date          name
17% (17%)    0% ( 0%)  Nov 30 09:00  hourly.0
20% ( 4%)    0% ( 0%)  Nov 30 00:00  nightly.0
22% ( 4%)    0% ( 0%)  Nov 29 19:00  hourly.1
25% ( 3%)    0% ( 0%)  Nov 29 14:00  hourly.2
27% ( 4%)    0% ( 0%)  Nov 29 09:00  hourly.3
LTDCLSERGAO
strange !!!!
Could you verify the date at which you disabled the aggragat snap sched ?
Is there any script taking this snap ?
If no , delete this snap and observe what is going to take place.
PASCAL_78
I disabled agregate snap sched on Nov 30, to see if agregate snapshots will be the same size in the future or not.
But i noticed that it was the same problem and agregate snapshot are using more and more space, so the agregate free space is goig down, whereas no agregate scheduling is active.
LTDCLSERGAO
OK.
Snapshots  keep track of the blocks that have changed  between snapshots and the current filesystem. The  changes  introduce to a filesystem can  increases  the snapshot size.
If you dont' need those snap, delete them.
PASCAL_78
Thanks Said.
I deleted all existing agregate snapshots, I'll see tomorow if somme agregate snapshots will be generated or not.
I hope "no".
PASCAL_78
Thanks you Said.
uptimenow
Also note that when you delete aggregate snapshots, not all blocks are freed immediately. There's a WAFL scan running to reclaim the freed aggregate blocks ... This may distort any "df -A" or "aggr show_space" figures you look at.
