ONTAP Hardware
Procedure to install HBA card in FAS 3210
NAYABSK
Hi All,
We are planning to install a new HBA on to a free available PCIe slot , Can anybody help me with the procedure or document to proceed , Like first to failover the controller ,  unscrew the controller, how to locate the free PCIe slot for HBA , and procedural document with pictorial representation would be more helpful. I understand 3210 is dual controller in a single 3U chasis, In this case how it would be performed ?
Thanks,
Nayab
2 REPLIES 2
georgevj
The document is available here.
Replacing PCIe cards in a 32xx system
https://library.netapp.com/ecm/ecm_download_file/ECMM1280370
Before adding the card to the storage system, please make sure that the card is supported for your platform and Data ONTAP version. Details about supported card types and supported slot assignments for each card is available at hardware universe.
http://hwu.netapp.com/Controller/Index
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
NAYABSK
I Found this video exactly what i am looking for.......
https://www.youtube.com/watch?v=K_2RkOB4oEw
