ONTAP Hardware
what is maximum 64bit aggr size and maximum volume size for fas3240?
MARIKOTAGAWA
Hi,
I'm looking for a space sheet for FAS6240.
I need the maximum 64bit aggregate size and volume for FAS6240.
Thank you
Mariko
1 ACCEPTED SOLUTION
deepuj
You can find it yourself by logging in to http://hwu.netapp.com/
Under Controllers select FAS/V-series
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
4 REPLIES 4
deepuj
Hi ,
Which version of ONTAP? Are you looking for FAS 3240 or 6240?
Thanks
MARIKOTAGAWA
Hi,
Sorry for the wrong model# in my first post.
I'm looking for the maximum 64bit aggregate size for FAS3240 (N6240), which ONTAP is 8.1.2 7-mode.
deepuj
Thanks
MARIKOTAGAWA
Hi, DEEPUJ.
Thanks a lot for the location of the spec sheet. I got the maximum aggreagete and volume size for FAS3240 with ONTAP8.1.2 7-mode.
Thank you.
