ONTAP Hardware
RLM naroot password
alexander7
Hello All!
Can the root user of FAS3140 change the naroot password of its RLM?
Thank you if you answer.
4 REPLIES 4
alexander7
Excuse me, I have already found an answer. We can use command
rlm setup
After that we can login to set up address with naroot and the empty password.
lopezj
Hi Alexander,
Data ONTAP root and RLM naroot user share the same password.
An easy way to replace them is just use the "passwd" command.
Cheers,
                  Jose Lopez
                  NetApp PS
subhash77us
What are the options if you have forgot the root password?
bbjholcomb
I believe the only way to change it, reboot the filer, get in maintenance mode, you will presented with a list, one of them is reset root password. You should be connected to the serial port.
