ONTAP Hardware
Recommended raid group size
jeroendevries
Hi,
I would like to know what your suggested Raid group size and number of disks is by Raid Type RAID-DP. Also would like to have two Aggregates for max IOPS.
Specs:
NetApp FAS2240-2, HA, 24x450GB (SAS 10K), Dual Controller met Data ONTAP
Essentials met Data ONTAP, DSM, MPIO, CIFS, NFS, iSCSI, FCP
en Local SyncMirror
Thanks.
1 REPLY 1
peter_lehmann
With this config (assuming a "load balance" HA Setup) you are not facing the raidgroup size question...
two controllers / each with one aggr0 of 11 disks, leaving 1 spare disk per controller...
Peter
PS default raidgroup size with SAS disks is 16 disks per RG (max 28)
RAID-DP (Default)
ATA/BSAS/SATA: 14     FC/SAS: 16     SSD: 23
(Maximum)
ATA/BSAS/SATA: 20     FC/SAS: 28     SSD: 28
RAID4 (default)
ATA/BSAS/SATA: 7     FC/SAS/SSD: 8
(Maximum)
ATA/BSAS/SATA: 7     FC/SAS/SSD: 14
