ONTAP Hardware
SVMDR from 9.1 to 9.4 ?
albertbon2012
Hi,
We have a customer who owns a FAS2240 7-Mode.
He wants to replace it with a FAS2750 in cDot and reuse its FAS2240 converted to cDot to create a PRA using SVMDR.
So the question is : "Is it possible to make SVMDR between a FAS2240 in cDot 9.1 to a FAS2750 in cDot 9.4"
Thanks in Advance
1 ACCEPTED SOLUTION
GidonMarcus
Hi
Version-independence is not supported for SVM replication.
http://docs.netapp.com/ontap-9/index.jsp?topic=%2Fcom.netapp.doc.pow-dap%2FGUID-B9E36563-1C7A-48F5-A9FF-1578B99AADA9.html
You can use normal snapmirror if you like...
https://library.netapp.com/ecmdocs/ECMLP2492508/html/GUID-A8F2BEFF-9A84-4C75-B8ED-93DD6098C799.html
Gidi
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
2 REPLIES 2
GidonMarcus
Hi
Gidi
albertbon2012
Thanks.
Following sheets are clear.
Have a nice day
Best regards
