ONTAP Hardware
Setup help
jelsco
Just Started a new job and was given the task "Rack and hookup this netapp stuff" No one here knows anything about it and this is my frist time with it.
4 units
FAS2220 (dual controller)
FAS2240-4 (single controller)
2- DS424x disk shelvs
For all i know everything that was setup at one time is not here. Seems weird to have two controllers, am i able to just hook the 2240 just as another link along with the DS's?
I have attached a picture of how i have it racked, if someone could give insight to how you think it should all be connected. I do believe it was all connect with ethernet only, maybe fiber at the controllers.
i have included the consol from the fas2222
Phoenix SecureCore(tm) Server
Copyright 1985-2008 Phoenix Technologies Ltd.
All Rights Reserved
BIOS version: 8.1.0
Portions Copyright (c) 2008-2011 NetApp, Inc. All Rights Reserved
CPU = 1 Processors Detected, Cores per Processor = 2
Intel(R) Xeon(R) CPU           C3528  @ 1.73GHz
Testing RAM
512MB RAM tested
6144MB RAM installed
256 KB L2 Cache per Processor Core
4096K L3 Cache Detected
System BIOS shadowed
USB 2.0: MICRON eUSB DISK
BIOS is scanning PCI Option ROMs, this may take a few seconds...
Boot Loader version 4.1
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2011 NetApp
CPU Type: Intel(R) Xeon(R) CPU           C3528  @ 1.73GHz
Starting AUTOBOOT press Ctrl-C to abort...
Loading X86_64/freebsd/image2/kernel:0x100000/8450520 0x90f1d8/1278704 Entry at 0x801585d0
Loading X86_64/freebsd/image2/platform.ko:0xa48000/653264 0xb8d8e8/692592 0xae77e0/39304 0xc36a58/42192 0xaf1168/86252 0xb06254/63752 0xb15b60/140448 0xc40f28/158856 0xb38000/2016 0xc67bb0/6048 0xb387e0/304 0xc69350/912 0xb38910/1680 0xc696e0/5040 0xb38fa0/960 0xc6aa90/2880 0xb39360/184 0xc6b5d0/552 0xb39420/448 0xb64de0/12918 0xb8d7f8/237 0xb68058/83952 0xb7c848/69552
Starting program at 0x801585d0
NetApp Data ONTAP 8.1.2P2 7-Mode
Copyright (C) 1992-2012 NetApp.
All rights reserved.
md1.uzip: 26368 x 16384 blocks
md2.uzip: 4608 x 16384 blocks
* Press Ctrl-C for Boot Menu. *
Oct 14 18:33:09 [localhost:cf.nm.nicTransitionUp:info]: Interconnect link 0 is UP
Oct 14 18:33:10 [localhost:cf.rv.flush.handleExchange:info]: Flushing is active.
Cluster monitor: warning: firmware partner-sysid variable is not set
Oct 14 18:33:12 [localhost:cf.nm.nicTransitionDown:warning]: Cluster Interconnect link 0 is DOWN
Oct 14 18:33:12 [localhost:cf.rv.notConnected:error]: Connection for 'cfo_rv' failed.
Oct 14 18:33:15 [localhost:diskown.isEnabled:info]: software ownership has been WAabled for this system
Oct 1FL4 18:33 :15 [loCPcalhostLE:dcs.frDGameworkER.enable d:info]i: The DsCS fram eework inas enablbled on tedhis nod. e.
OChct 14 1ec8:33:15kl [localishost:cot nfig.no= Partner0Disks:Cx7RITICALff]: No r the pwe41re detefcted fof
artner; this node will be unable to takeover correctly
Oct 14 18:33:15 [localhost:callhome.dsk.config:warning]: Call home for DISK CONFIGURATION ERROR
Oct 14 18:33:15 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig'. The full command line is 'ifconfig lo 127.0.0.1'.
Oct 14 18:33:15 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. The full command line is 'ifconfig_priv losk 127.0.20.1'.
Oct 14 18:33:15 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. The full command line is 'ifconfig_priv lo 0'.
Oct 14 18:33:15 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. TPANIC  : raid: there are no data or parity disks
version: 8.1.2P2: Wed Feb 20 19:58:27 PST 2013
conf   : x86_64
cpuid = 0
Uptime: 38s
PANIC: raid: there are no data or parity disks in SK process rc on release 8.1.2P2 on Wed Oct 14 18:33:16 GMT 2015
compile flags: x86_64
Writing panic info to HA mailbox disks.
HA: current time (in sk_msecs) 17711 (in sk_cycles) 220546957837
DUMPCORE: START
No eligible disks found
DUMPCORE: END -- coredump *NOT* written.
Dumpcore failed
coredump: primary dumper failed -1.
coredump: trying secondary dumper...
no tftp server ip specified
netdump: no targets available to dump
coredump: secondary dumper failed -1.
Logging shutdown event to the SP...
System halting...
cpu_reset called on cpu#0
All Rights Reserved
BIOS version: 8.1.0
Testing RAM
512MB RAM tested
LOADER-A> boot_ontap
Oct 14 18:37:16 [localhost:netif.linkUp:info]: Ethernet e1b: Link up.
Oct 14 18:37:16 [localhost:netif.linkUp:info]: Ethernet e1a: Link up.
Oct 14 18:37:17 [localhost:diskown.isEnabled:info]: software ownership has been WAabled for this system
Oct 1FL4 18:37 C:17 [loPLcalhostED:dcs.frGameworkE.enableRd:info] i: The Ds CS framenework iabs enablleed on td.his nod e.
OChct 14 1e8:37:17c [localklhost:coisnfig.notPartner =Disks:C RITICAL0]: No dx7i this nfre dete84cted fo1fr the pfartner;
Oct 14 18:37:17 [localhost:callhome.dsk.config:warning]: Call home for DISK CONFIGURATION ERROR
Oct 14 18:37:17 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig'. The full command line is 'ifconfig lo 127.0.0.1'.
Oct 14 18:37:17 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. The full command line is 'ifconfig_priv losk 127.0.20.1'.
Oct 14 18:37:17 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. The full command line is 'ifconfig_priv lo 0'.
Oct 14 18:37:17 [localhost:kern.cli.cmd:debug]: Command line input: the command is 'ifconfig_priv'. The full commanPANIC  : raid: there are no data or parity disks
conf   : x86_64
cpuid = 0
Uptime: 38s
PANIC: raid: there are no data or parity disks in SK process rc on release 8.1.2P2 on Wed Oct 14 18:37:18 GMT 2015
HA: current time (in sk_msecs) 18067 (in sk_cycles) 391029278789
DUMPCORE: START
Dumpcore failed
System halting...
All Rights Reserved
BIOS version: 8.1.0
Testing RAM
512MB RAM tested
LOADER-A>
2 REPLIES 2
hariprak
Hi, For installation and setup instructions for FAS 2220/FAS2240 system please refer below link, https://library.netapp.com/ecm/ecm_download_file/ECMP1149275 For SAS disk shelves, universal SAS and ACP cabling guide refer, https://library.netapp.com/ecm/ecm_get_file/ECMM1280392 Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
jelsco
It is not possiable to use only ACP, correct? They eithey have to be connected with SAS or SAS+ACP?
