ONTAP Hardware
FAS2552, Nexus 3000, ESXi 5.5 VPC LACP config
ThePoster
Hey guys,
Having issues with communication between my devices.
I am trying to get a ping from either 3k2 or 3k3 in below image to the links i have created on my fas2552, any help would be greatly appreciated.
Both 3ks are connected via VPC peerlink (this is the green lines in image below)
   interface port-channel10
     switchport
     switchport mode trunk
     switchport trunk allowed vlan 1,400
     spanning-tree port type network
     vpc peer-link
The 3ks have vPC to individual controllers
interface port-channel101 (this is the blue lines in image below)
  switchport
  switchport access vlan 400
  no negotiate auto
  vpc 101
interface port-channel102 (this is the purple lines image below)
  switchport
  no negotiate auto
  vpc 102
vPC status shows active
id     Port        Status Consistency Reason                     Active vlans
101    Po101       up     success     success                    400
102    Po102       up     success     success                    400
HSRP gateway
Interface   Grp Prio P State    Active addr      Standby addr     Group addr
Eth1/44     2   110  P Active   local            172.16.250.3     172.16.250.1    (conf)
the FAS has 2 ifgrps on vlan 400 both active
            dmm1         up/up    172.16.250.211/24  GMK200-01     a0a-400 true (this is the blue lines in image below)
            dmm2         up/up    172.16.250.221/24  GMK200-02     a0a-400 true (this is the purple lines image below)
10 REPLIES 10
DREW_RUSSELL
Can you clarify whether or not you are running 7-Mode or clustered Data ONTAP on the NetApp Controllers? It should not affect the configuration but will help in terms of providing releveant commands if needed.
As for your vPC Configuration, po101 & 102 should be configured as switchport mode trunks and should also be configured as a spanning-tree port type edge trunk. For example:
switchport
switchport mode trunk allowed vlan 400
spanning-tree port type edge turnk
vpc 101
interface port-channel1012
switchport
vpc 102
Since the Nexus 3K has 1 Gb ports I would also keep auto negotiate enabled espeically if you are not connected to e0a and e0b on the FAS2554 side.
ThePoster
Hi Drew,
I have configured ports as per your advice and still no luck 😞
  switchport
  no negotiate auto
  vpc 101
  switchport
  no negotiate auto
  vpc 102
i am unable to remove the 'no negotiate auto' error - 'ERROR: port-channel101: Configuration does not match the port capability.'
could this be because they are 10Gb links?
we are running clustered data onTap
DREW_RUSSELL
Can you try running negotiate auto on the individual ports and see if that works?
Also, can you clarify what exactly you're trying to ping (i.e from what to what)?
On the Nexus 3K side can you run a show interface brief ?
On the FAS2554 can you run the following:
  • network interface show
  • network port show
  • network port show -node GMK200-01 -port a0a-400  (correct the syntax for your setup if i messed that up)
  • network port show -node GMK200-02-port a0a-400  (correct the syntax for your setup if i messed that up)
  • network traceroute -node GMK200-01  -destination <Remote InetAddress>
ThePoster
Hey Drew,
I got the ping working, setting to trunk port and spanning tree edge was the fix.
After executing those settings, i tried pinging from the 3k and it failed.. then i reposted, and it came to me that i should try pinging from one of the edge devices as there is no vlan interface on the 3k.
did the ping from UCS (vmware host) to the netapp and it worked!!!!
thanks for your help, i can begin the iSCSI initialization now 🙂
DREW_RUSSELL
Awesome!! Glad you're up and running.
ThePoster
So now that i am able to ping the devices i am having issues finding the storage device through iSCSI.
I have setup igroups
GMK200::> igroup show
Vserver   Igroup       Protocol OS Type  Initiators
gmk200-iscsi
          GMK-VM-02    iscsi    vmware   iqn.1998-01.com.vmware:gmk-vm-02-
                                         68baaf70
but when i scan on my software adapter on vmware it doesnt find anything. any ideas, or should i be posting on a vmware forum??
DREW_RUSSELL
We can certainly help here! However, I would create a new post just to make sure your issue does not get burried here.
To stat with though I would make sure that your vServer is configured for iSCSI. You can do a vserver show and then look for the Allowed Protocols section. Also you'll need to make sure that you have at least one iSCSI LIF configured on the SVM.
Can you also confirm which NIC you are using in your UCS Blades?
ThePoster
We are using Cisco VIC ethernet NIC , 10GB on the UCS220
I have created a LAG on the esxi host, which links 2 of the 10gb ports.
This sits on a distributed switch but when i try and bind the storage adapter to a vmkernel it doesnt find the one i have created and attached to the dSwitch.
It appears only vSwitch kernels are shown
Below is some more infor from the netapp side, please let me know if i can supply more.
thx
GMK200::> vserver show
                    Admin     Root                  Name    Name
Vserver     Type    State     Volume     Aggregate  Service Mapping
GMK200      admin   -         -          -          -       -
GMK200-01   node    -         -          -          -       -
GMK200-02   node    -         -          -          -       -
gmk200-iscsi
            data    running   gmk200iscs aggr_      file,   file
                              i_root     GMK200_1_  nis
                                         Flash
gmk200-iscsi
                                         68baaf70
GMK200::> network interface show
            Logical    Status     Network            Current       Current Is
Vserver     Interface  Admin/Oper Address/Mask       Node          Port    Home
GMK200
            cluster_mgmt up/up    192.168.115.9/24   GMK200-02     e0M     true
GMK200-01
            clus1        up/up    169.254.125.254/16 GMK200-01     e0e     true
            clus2        up/up    169.254.76.228/16  GMK200-01     e0f     true
            mgmt1        up/up    192.168.115.10/24  GMK200-01     e0M     true
GMK200-02
            clus1        up/up    169.254.3.63/16    GMK200-02     e0e     true
            clus2        up/up    169.254.245.78/16  GMK200-02     e0f     true
            mgmt1        up/up    192.168.115.6/24   GMK200-02     e0M     true
gmk200-iscsi
ThePoster
please disregard my stupidity. i have found out why i was not able to find the LUN... during earlier testing i had CHAP auth enabled. when i cancelled it on the netapp side during our network issues i forgot to remove from vmware. i removed and found the LUN!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! 🙂 🙂 🙂
Thanks again, it all makes sense now :)\
AVAZQUEZ79
Hello Poster,
Can you please share your Po config?  I am having some challenges with our config.
Thanks!
