ONTAP Hardware
SnapCenter Plug-in for VMware vSphere (4.8)
zzzostapetszzz
help download, says no access
FAS2750 (S/N 652040000081/82)
1 ACCEPTED SOLUTION
Ontapforrum
I am able to download this version. So, it may be something to do with your Support entitlements. Please open a non-technical case with NetApp support. In case you have just opened an account, then it may take 24 hrs before you get an access. It's better to just speak with support.
How to open a non-technical case:
https://kb.netapp.com/Support/General_Support/How_to_open_a_non-technical_case
How to request full customer level access on the NetApp Support Site - NetApp Knowledge Base
3 REPLIES 3
Ontapforrum
zzzostapetszzz
most likely it is 🙂
can I ask you to download this software if I can't?
Ontapforrum
I would advise you to wait until you get an access or Just reach out to Support, I am sure they will expedite it.
How do I access Software Downloads? - NetApp Knowledge Base
