ONTAP Hardware
Syslog descriptions for Splunk filtering
EdwardTSV
Hi folks,
I am looking for a document for NetApp (FAS and V-series) syslog user guide.
I am pointing my Netapp syslog to Splunk and I want to filter out modification/alternation events for Splunk pick-up.
Is there a document that lists each syslog event that I can download?
Thanks in advance.
4 REPLIES 4
Sahana
Hi,
Refer https://library.netapp.com/ecmdocs/ECMP12458569/html/GUID-9F8EB0DF-12F5-4DA9-B14B-34487DE3717D.html to setup a splunk or syslog server.
refer http://mysupport.netapp.com/NOW/knowledge/docs/olio/autosupport/matrices/ for syslog translator
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
EdwardTSV
Thanks for the recommendations.
But I was not able to get a whole list of syslog events. The syslog translator only lists using keywords.
Is there a list of all the EMS identifiers?
Alternatively, is there a string for only modification/alternation events?
elementx
AI spam
EdenWheeler
Yes, NetApp provides a syslog user guide that includes information on FAS and V-series systems. This guide lists the various syslog events and provides details on how to configure and customize Syslog settings. You can download the guide from the official NetApp website.
