ONTAP Hardware
Steps for changing FAS controllers but with DOT 7-mode on both
JoseCasaux
Hello folks, can somebody tell me the steps needed for changing an old FAS3220 controller and put instead a FAS2552 controller? Please consider that DOT 7-mode OS will be on the new controller (as on the old one). Thank you in advance.
1 ACCEPTED SOLUTION
shatfield
Here are the steps, but you should note thats not a supported upgrade path:
Upgrading a system in an HA pair to a different system in an HA pair by moving disk shelves
2 REPLIES 2
shatfield
JoseCasaux
Thank you man
