ONTAP Hardware
Upgrade ONTAP FAS960c
piotr_stanczak
Hi, I try upgrade ontap 7.2.3 to 7.3.6 on fas960c all go just ok, an until restart the head. afther restart I have still last version of system.
version -b
1:/x86/kernel/primary.krn: OS 7.3.6
1:/backup/x86/kernel/primary.krn: OS 7.2.3
1:/x86/diag/diag.krn:  Diagnostic_5.5.2
1:/x86/firmware/xfiler/firmware.img: Firmware 4.3.1_i2
1:/x86/firmware/rodan/firmware.img: Firmware 4.3.1_i1
all procedure upgrade was done sucessfull no errors
Can you give a clue or idea. What to do?
4 REPLIES 4
aborzenkov
Your primary kernel is 7.3.6. Where exactly do you see old version?
piotr_stanczak
Hi, Problem resolved I secend time upgrade FAS and sacessfull finish updrade. Tnx for help.
piotr_stanczak
Secend line old is 7.3.2 new 7.3.6
aborzenkov
Secend line
Second line shows previous kernel version before update. It is there so you can (more or less easily) revert in case something goes extremely wrong.
