ONTAP Hardware
Upgrading filer from 8.0.2 to 8.0.2p3
GUVNIJJAR
I have a filer FAS 3240 with software version 8.0.2 and want to upgrade the software to 8.0.2p3.   Can someone advise on the steps on how to do this.  Such as firstly where to download the software from, and then how to approach the upgrade, and what we should shut down first, end sessions etc, and then how to do the upgrade, and what to check afterwards when the upgrade is completed, such as logs etc.
Any advise.  Are there any good links which shows the steps.
Thanks
1 REPLY 1
vmsjaak13
Go to My Autosupport, select your system, and check out 'Upgrade Advisor'.
Furthermore on the documentation page of the NOW site, there's a great PDF on upgrading.
Regards,
Niek Baakman
