ONTAP Hardware
I have a sparing problem where a 1TB SATA spare will not spare out a failed 750GB SATA disk on a FAS3040
rdunkerson
I have a sparing problem to where a 1TB SATA spare will not spare out a failed 750GB SATA disk on a FAS3040.  All firmware is up to date on the disks so I am at a lost considering the rules for spares says a larger disk should spare into the aggregate.
Spare disks
RAID Disk       Device  HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)    Phys (MB/blks)
spare           1d.18   1d    1   2   FC:B   -  ATA   7200 847555/1735794176 847827/1736350304
8 REPLIES 8
aborzenkov
Please show aggr status -r output.
rdunkerson
netapp3040b> aggr status -r
Aggregate t3_aggr1 (online, raid_dp) (block checksums)
  Plex /t3_aggr1/plex0 (online, normal, active)
    RAID group /t3_aggr1/plex0/rg0 (normal)
      dparity   2d.16   2d    1   0   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      parity    2b.32   2b    2   0   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2d.48   2d    3   0   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.64   2d    4   0   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.17   2d    1   1   FC:A   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.33   2b    2   1   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.49   2b    3   1   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.65   2b    4   1   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.18   2d    1   2   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.34   2d    2   2   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.50   2d    3   2   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.66   2b    4   2   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.26   2d    1   10  FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.35   2d    2   3   FC:A   -  ATA   5400 274400/561971200  274540/562258784
    RAID group /t3_aggr1/plex0/rg1 (normal)
      dparity   2d.51   2d    3   3   FC:A   -  ATA   7200 274400/561971200  274540/562258784
      parity    2b.67   2b    4   3   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.36   2d    2   4   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.20   2d    1   4   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.52   2b    3   4   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.68   2b    4   4   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.37   2b    2   5   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.21   2b    1   5   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2d.53   2d    3   5   FC:A   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.69   2b    4   5   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.38   2b    2   6   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2d.22   2d    1   6   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.54   2d    3   6   FC:A   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.70   2b    4   6   FC:B   -  ATA   5400 274400/561971200  274540/562258784
    RAID group /t3_aggr1/plex0/rg2 (normal)
      dparity   2b.39   2b    2   7   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      parity    2d.71   2d    4   7   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.23   2d    1   7   FC:A   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.55   2b    3   7   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.40   2b    2   8   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.72   2b    4   8   FC:B   -  ATA   7200 274400/561971200  274540/562258784
      data      2b.24   2b    1   8   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.56   2b    3   8   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.41   2d    2   9   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.73   2b    4   9   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.25   2d    1   9   FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.57   2b    3   9   FC:B   -  ATA   5400 274400/561971200  274540/562258784
      data      2d.42   2d    2   10  FC:A   -  ATA   5400 274400/561971200  274540/562258784
      data      2b.74   2b    4   10  FC:B   -  ATA   5400 274400/561971200  274540/562258784
Aggregate t3_aggr0 (online, raid_dp, degraded) (block checksums)
  Plex /t3_aggr0/plex0 (online, normal, active)
    RAID group /t3_aggr0/plex0/rg0 (normal)
      dparity   1b.32   1b    2   0   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      parity    1b.33   1b    2   1   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.29   1d    1   13  FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.35   1b    2   3   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.36   1b    2   4   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.37   1b    2   5   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.26   1b    1   10  FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.39   1b    2   7   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.40   1b    2   8   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.24   1d    1   8   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.42   1b    2   10  FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.43   1b    2   11  FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.44   1b    2   12  FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.16   1d    1   0   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
    RAID group /t3_aggr0/plex0/rg1 (degraded)
      dparity   1d.17   1d    1   1   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      parity    1b.45   1b    2   13  FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.38   1b    2   6   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.19   1d    1   3   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.28   1d    1   12  FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.21   1d    1   5   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.22   1d    1   6   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      FAILED          N/A                   635555/1301618176
      data      1d.20   1d    1   4   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1d.25   1d    1   9   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.41   1b    2   9   FC:A   -  ATA   7200 635555/1301618176 635858/1302238304
      data      1b.34   1b    2   2   FC:A   -  ATA   7200 635555/1301618176 847827/1736350304
Aggregate t3_aggr3 (online, raid_dp) (block checksums)
  Plex /t3_aggr3/plex0 (online, normal, active)
    RAID group /t3_aggr3/plex0/rg0 (normal)
      dparity   2d.96   2d    6   0   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      parity    2b.97   2b    6   1   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.98   2b    6   2   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.99   2d    6   3   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.100  2d    6   4   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.101  2d    6   5   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.102  2b    6   6   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.103  2b    6   7   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.93   2b    5   13  FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.105  2b    6   9   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.106  2d    6   10  FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.107  2d    6   11  FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.108  2d    6   12  FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.104  2d    6   8   FC:A   -  ATA   7200 423111/866531584  423889/868126304
    RAID group /t3_aggr3/plex0/rg1 (normal)
      dparity   2d.80   2d    5   0   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      parity    2b.81   2b    5   1   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.82   2b    5   2   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.83   2d    5   3   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.84   2d    5   4   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.85   2d    5   5   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.86   2b    5   6   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.87   2b    5   7   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.88   2d    5   8   FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.89   2b    5   9   FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2b.90   2b    5   10  FC:B   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.91   2d    5   11  FC:A   -  ATA   7200 423111/866531584  423889/868126304
      data      2d.92   2d    5   12  FC:A   -  ATA   7200 423111/866531584  423889/868126304
Spare disks
Spare disks for block or zoned checksum traditional volumes or aggregates
spare           2b.44   2b    2   12  FC:B   -  ATA   5400 274400/561971200  274540/562258784
spare           2b.58   2b    3   10  FC:B   -  ATA   5400 274400/561971200  274540/562258784
spare           2b.59   2b    3   11  FC:B   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.28   2d    1   12  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.29   2d    1   13  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.60   2d    3   12  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.75   2d    4   11  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.76   2d    4   12  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2d.77   2d    4   13  FC:A   -  ATA   5400 274400/561971200  274540/562258784
spare           2b.45   2b    2   13  FC:B   -  ATA   7200 274400/561971200  274540/562258784
spare           2d.27   2d    1   11  FC:A   -  ATA   7200 274400/561971200  274540/562258784
spare           2d.43   2d    2   11  FC:A   -  ATA   7200 274400/561971200  274540/562258784
spare           2d.61   2d    3   13  FC:A   -  ATA   7200 274400/561971200  274540/562258784
spare           2d.109  2d    6   13  FC:A   -  ATA   7200 423111/866531584  423889/868126304
Broken disks
not responding  2b.19   2b    1   3   FC:B   -  ATA   5400 274400/561971200  274540/562258784
failed          1d.23   1d    1   7   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
not responding  1d.27   1d    1   11  FC:B   -  ATA   7200 635555/1301618176 635858/1302238304
aborzenkov
Yes, looks like it ignores suitable spare. Do you have any suspicious messages in /etc/messages about it?
rdunkerson
Just the error that the raid roup is degraded because it can not spare in a disk out of the spares pool
chrism
You can add the disk in manually by throwing the "-f" flag at the end of the command to force it. It looks like that aggregate was initially created with 750GB SATA drives which is possibly why it is fighting back. While OnTap should be throwing it in and downsizing the drive, that's probably where it's choking.
Also, with your mix and match SATA aggregates I would also make sure that "options raid.rpm.ata.enable" is set to on so it plays nicely as well.
aborzenkov
Just a wild guess - may be outdated disk qualification package.
rdunkerson
I have the latest devices_qual_v2 file out in etc
rdunkerson
  "options raid.rpm.ata.enable" is on but now this is weird we rplaced to 750GB drives that were in the broken disks but I can not see those disks in the slots for the aggregate.  There are 2 of 1TB drives in shelf 1 bays 7 and 12 but I do not see them when I issue a sysconfig -r and note I can see them from a sysconfig -v.
      data      1b.18   1b    1   2   FC:A   -  ATA   7200 635555/1301618176 847827/1736350304
      data      FAILED          N/A                   635555/1301618176                                                       This raid group is not showing the disks in bay 7 and 12 of
      data      1d.20   1d    1   4   FC:B   -  ATA   7200 635555/1301618176 635858/1302238304            shelf  1
