ONTAP Hardware
Use FAS2220 as DAS?
terragenesis
Hi,
Would like to ask if this is possible?
I would like to reduce the load on my switches, that is why I am looking into this.
I am currently running both controllers in HA mode.
I am trying to add the iSCSI initatiors on the server but I am unable to detect them.
1 ACCEPTED SOLUTION
SYNTAXERROR
If you are using 8.1.4 7-Mode it is not supported to have a direct attached connection to a HA pair but you can use it if you only have one controller:
https://library.netapp.com/ecm/ecm_download_file/ECMP1224558
At the bottom of page 8
4 REPLIES 4
SYNTAXERROR
terragenesis
Hi Syntaxerror,
Thanks going to check it out now!
edit: any idea if it will work with ontap8.1.4?
SYNTAXERROR
terragenesis
So I can technically have 2 controllers and run each of them with teaming to my server?
