ONTAP Hardware
V-Series FMC Switches
byermann
I'd like to confirm the switches that are supported by NetApp when configuring a V-Series Fabric MetroCluster.
The restrictions that apply to FAS based FMC's regarding Brocade switches does not apply to a V-Series FMC ?
Thanks for your help.
1 ACCEPTED SOLUTION
isaacs
Hi Bruce,
While V-Series currently supports a broader group of switches than FAS, NetApp disks are currently not supported in V-Series Metrocluster configurations.  To use a V-Series to avoid the switch restrictions of FAS means you give up using NetApp disks.
Thanks!
Daniel Isaacs
Technical Marketing Engineer - VBU
V-Series
NetApp
919.412.0937 Direct
[email protected]
www.netapp.com
2 REPLIES 2
boonstra
isaacs
Hi Bruce,
Thanks!
Daniel Isaacs
V-Series
NetApp
919.412.0937 Direct
[email protected]
www.netapp.com
